Cessna Fuel bowl
Any info on how to tell if your gascolator bowl Is affected by the recent service bulletin?
George
    Very good question. I'm hoping one of our members has that answer!
  • The notice was timely for my 150F. Inspection found much corrosion. Worse was that the plunger tip was hardened and cracked in half-just short of failure.
    down load the SB, tells you what markings to look for. carl
