Real Gasket Push Rod tube leakage and hylomar
I have the tubes installed on an O300D and am pleased with the results. Occasionally a leak will occur on the crankcase end and the parts can be replaced. My question regards a suggestion that I believe I saw in the Q&A section regarding the use of hylomar on the new replacement parts. I am not able to open the September digital back issue? but I've checked the others to no avail. Does anyone else recall that information or is my mind just slipping?!!! Thanks for the help.
    Have you ever used aviation form a gasket by permatex? It's does the exact same thing as the hylomar does. Not hardening and nice and sticky. Carl
